Idle Rough While In Gear
Old Mar 10, 2011 | 09:34 PM
challenger383auto's Avatar
challenger383auto
Default Idle Rough While In Gear
Just got a used motor put in my truck two weeks ago. Has 115000 miles on it. Runs real good, except when i come to a stop light, after sitting for maybe a minute or so, sometimes it starts to idle rough, however i can step on the gas and goes like nothing is the problem, OR i can shift it into neutral and it idles fine. Any ideas?
Old Mar 10, 2011 | 11:35 PM
Check the plenum. Also, how old are your O2 sensors?
Old Mar 11, 2011 | 08:01 AM
challenger383auto
My O2 sensor is a little more than one year old... Plenum was replaced already and still looks clean... Anything to do with the throttle body? Thats what im leaning towards.
Old Mar 11, 2011 | 10:17 AM
Cleaning the throttle body, and verifying the TPS is doing what it is supposed to wouldn't hurt.
Also check for vacuum leaks.
Did you give the new engine a tune up?
Might wanna try giving the engine a seafoam treatment. (feed it in thru a vacuum line)
