rough on occasion
Old Mar 14, 2011 | 01:48 PM
Mad_Scientist's Avatar
Mad_Scientist
Front O2 is mounted directly into the cat, right where the two pipes come in from the manifolds... so, it is easy to hit..... If it is original, or, has been in there a long time, replacing it on general principles is not out of order.
Actually, on his '99, the o2 is in the collector pipe shortly before the cat. Dodge changed the cat setup in 98 to SI/SO and moved the o2 forward a bit.
Not saying he didnt smack it, just that it's harder to do with this setup as opposed to the pre-'98 one.
Glad you seem to have it fixed (*touch wood*) velocity37; give us the final word when you are certain.
