Another bad MPG thread (but hey, at least I'm not gonna mention the plenum)
Is the .9 volts supply voltage, or is that what the PCM is seeing as the return? Supply should be 5 volts. Return should vary between zero and one. A digital meter doesn't react fast enough though, the scanner should display accurate data though, provided it samples often enough.
Yup. Or, the sensor is simply lying...... Ideally, it should bounce between values greater, and less than.. .45 volts. If it stays higher, its running rich, lower, lean. How old is the sensor??
Is the PCM going into closed loop?
