Alternator Clacking
Old Mar 14, 2011 | 11:09 AM
BamaRam97's Avatar
BamaRam97
Default Alternator Clacking
I have been having a squeaking noise from the front of my truck for quite a while now. I took the belt off and cranked her up and no noise. I put a new idler pulley and and new tensioner arm and pulley on and the squeaking persisted. The noise has progressively gotten worse and has now turned into a metal on metal sound. I checked my alternator today and when turning it with no belt I can feel a distinct drag at one point. I suppose this is the bearing in the alternator locking up? What brand alternator do you all recommend? I'm thinking either the Bosch or Napa brand. Suggestions?
Old Mar 14, 2011 | 12:07 PM
Get one with a lifetime warranty. If you plan on adding power hungry accessories to your truck, get one with a higher rated output than stock as well.
I bought ONE alternator for my firebird. I replaced it four times in the ten years I owned it.
Old Mar 14, 2011 | 12:14 PM
BamaRam97's Avatar
BamaRam97
I'm not sure if I have the 90 or 136 in my truck now, but if I do upgrade will I need to upgrade anything else? Fuses, relays, etc?
EDIT: My build sheet says it is a 117, so I am going to go w/ the Bosch 136. Bosch is about as good as it gets right?
Old Mar 14, 2011 | 12:20 PM
Probably just the input fuse for the alt, in the PDC. (or would that be the output fuse? Too early in the morning for me....... )
Old Mar 14, 2011 | 12:23 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You don't need to change anything except the generator itself.
