2wd 1500 rearend swap to 2500
Old Mar 14, 2011 | 11:17 AM
dipsherry's Avatar
dipsherry
Default 2wd 1500 rearend swap to 2500
so i am looking to swap my whole rear end after this weekend i am tired of mine...i am looking for a 3/4 ton rear with the 4.10s it seems to be the cheaper route other than them being 8 lug is there anything else to look out for. i am sure i can call advance adapters and have some 8 lug to 5 lug adapters... does this make sense that it should work or am i crazy
Old Mar 14, 2011 | 12:03 PM
I think you are going to have a fun time trying to find a Dana 60 with 4.10s..... most of them will still be 3.55s.
Are you having issues with your current diff?
Old Mar 14, 2011 | 12:12 PM
dodgeram07's Avatar
dodgeram07
For the price of adapters your can buy used 8lug rims( dodge ford chevy all will work)
Old Mar 14, 2011 | 12:29 PM
dipsherry's Avatar
dipsherry
well i figured while i was doing all this work on my truck i would change the rear end fluid and look at why my truck is now only a 1 wheel wonder.. well i got in there and the clutch packs ( i assume thats what they are) in the lsd are toast and the gears are showing wear. i found a 94 2500 with 4.10 the dude showed me a build sheet for the truck so i figured y not. 550 bucks for the whole gitup drum to drum
Old Mar 14, 2011 | 12:32 PM
Does the new rear have an LSD? If it does.... that really isn't too bad of a price. E-brake cables might have to be swapped as well, but, that is a pretty minor issue.
Keep in mind also, that your rear brakes are going to be MUCH more effective on the 3/4 ton rear end...... adjustable proportioning valve time?
Old Mar 14, 2011 | 12:38 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I think most if not all, 2500's with a 60 rear end is going to have 4:10's. Atleast if it comes off a 4wd, and it's not an early model light duty 2500. Only problem will be drive shaft and the fact the leaf spring are different width's.
Old Mar 14, 2011 | 12:44 PM
I have a 96 3/4 ton, with D60's front and rear, and got stuck with 3.55s...... something that REALLY needs to change.
Old Mar 14, 2011 | 12:56 PM
zman17's Avatar
zman17
That's where the light duty or original owner specified something different for the use of the truck comes into play., or to put a better mpg sticker on the it from Dodge. I recently dealt with a 99 4x4 that had 3:55's. Turn's out the owner had the choice, mpg related for the main use of the truck.
Old Mar 14, 2011 | 12:59 PM
dipsherry's Avatar
dipsherry
i looked at the u joints they both seemed similar and the leaf springs plates on the 3/4 ton are wider but i dont think that will matter i dont plan on swapping the whole setup just the rear end itself gonna keep my 1500 springs. should i measure u joint or how should i go about checking to see if they will work
Old Mar 14, 2011 | 01:02 PM
Measure u-joints on both trucks. Diameter of the cap, and Length of the cross. You can probably get a hybrid u-joint with the correct sizes on each of the crosses to put the 1500 shaft, on the 2500 axle. If the shaft is too long though..... that is going to require that you be a bit more creative.
Given that the cost of this is climbing rapidly..... a detroit locker for the 9.25 can be had fairly cheap on the used market.....
