Old Aug 10, 2015, 05:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
What does it mean when I have play in my steering and squeaking noises?
Old Mar 20, 2011 | 02:23 AM
vikingdiesel's Avatar
vikingdiesel
replace the whole shaft?
Old Mar 20, 2011 | 02:32 AM
vikingdiesel
Is this pretty much what I need, PLUS the IDLER ARM and PITMAN ARM? And the $50 bushing? Also, are 2500 and 3500 the same and are all 94-01 the same or no? Also, will my OFF-ROAD work with a STOCK pitman or is the pitman arm or any other parts on the OFF-ROAD different (suspension wise, NOT shocks/springs)?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Mar 20, 2011 | 09:10 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you get help from a friend to check the components as described earlier? Or are you just wildly spending money and replacing everything, whether it's bad or not?
Old Mar 20, 2011 | 09:29 AM
vikingdiesel
im wildly spending money pretty much a little and yes the pitman arm, idler arm and track bar are all bad, since I use this trunk for long distance, I might as well change all this stuff.
Old Mar 20, 2011 | 09:40 AM
zman17's Avatar
zman17
Allrighty then. Don't by an Idler arm though. 4WD does not have one.
Old Mar 20, 2011 | 10:18 AM
vikingdiesel
the link I posted, seems good?
Old Mar 20, 2011 | 11:18 AM
Seems awfully cheap to me. I paid almost 150 just for my track bar. The 'one year warranty' kinda reinforces the 'cheap' supposition.
Old Mar 20, 2011 | 11:29 AM
zman17's Avatar
zman17
Take the time to find out what parts are worn and spend the money on replacing the bad parts with better quality. You'll just wind up replacing cheap parts you replaced, again for no reason. Do what you want, but IMHO your course of action is ridiculous.
Old Mar 20, 2011 | 12:49 PM
vikingdiesel
I'm just trying to buy a whole suspension kit, what's so ridiculous with that, I want to get all new front end parts, that's all
Old Mar 20, 2011 | 12:53 PM
Consider what your front end parts do for you, and what you do TO them..... That is NOT an area that you want to cheap out on. You would be much further ahead by doing a VERY thorough inspection, find out what's bad, and then replace those parts with QUALITY parts. Yeah, its more expensive that way, initially...... but, in the long term, you will replace far fewer parts that way.
What's the point of saving a few bucks to get cheap, low-quality parts, that you will have to replace again in maybe another year?
