after pulling how much weight should I NOT use (OD)?
Old Mar 20, 2011 | 02:23 AM
drewactual's Avatar
drewactual
if your not searching for gears excessively your okay.. the thing is, i seriously doubt your torque converter locked up, and since it didn't- you were amplifying torque- which heats up a tranny real quick like.
if it's not slipping, I'd guess you're okay.. but I wouldn't risk it anymore..
Old Mar 20, 2011 | 02:26 AM
vikingdiesel's Avatar
vikingdiesel
aight, so just to confirm, im pulling about 5-6k lbs TOTAL, I have an 01 RAM 1500 OFF-ROAD with 33" tires, im driving about 70 mph, (OD) should BE OFF even at 70+mph and at HIGH REVS, MPG will suffer but TRANS will be strong and I dont have to worry about over heating the trans? With the motor reving that HIGH constantly, I feel like im putting a lot of strain on the motor though?? I mean, driving 500 miles and doing 70mph with the engine revving at 4k rpm, thats normal?
Old Mar 20, 2011 | 02:30 AM
drewactual's Avatar
drewactual
that's about right with that kind of weight behind you.. these engines are solid when they're tuned.. wouldn't worry about the engine.. I would worry about the tranny, and the way to protect it is to keep the o/d off with anything over 1k# behind you, and no matter the speed or sustained speed..
Old Mar 20, 2011 | 06:09 AM
93grandzj's Avatar
93grandzj
i towed my buddies tahoe boat and that was a load. i have the same set up as you. i took the OD off up hills, and flat and down hill left her in never had a hiccup. its true just be careful and keep in mind if your searching your destroying. haha COD black ops rules XBOX 360.
Old Mar 20, 2011 | 07:47 AM
Kwdog75's Avatar
Kwdog75
The bigger question is why are you going 70 mph with a trailer behind you with a car on it? I wouldn't be doing anything over 65 mph, you'll save money in gas and wear and tear on your pickup. And keep the o/d off. Being a trucker i've seen way too many people pulling trailers too fast only to see a disastrous results. If you blew a tire doing 70 mph, you'd be in a whole lotta trouble in a hurry. The extra minutes it will take you to get to your destination will be worth it. Spend the money and get a weight distribution hitch, they are worth their weight in gold!
Just my 2 cents.
Old Mar 20, 2011 | 09:16 AM
redneck_ram's Avatar
redneck_ram
i regularly tow a 3-4k# camper in the summer, i have a controller, but i dont use weight distribution. my truck barely squats, and i have the controller set properly. the farthest i tow it is probly 100 miles, od is always off. havent had any problems yet, and my rear brakes probly have 50k miles left to them or so.
Old Mar 20, 2011 | 10:17 AM
vikingdiesel
my truck doesnt squat either, this is just an 18ft flatbed trailer for a car,
Old Mar 20, 2011 | 10:47 AM
jasonw's Avatar
jasonw
Site Moderator
Even downhill or with flat areas, keep O/D off. It will generate to much heat even in those areas with over 1k lbs in the back, and will most likely cause problems later, unless you have a deep tranny pan, larger transmission cooler, etc. etc.
Old Mar 20, 2011 | 11:36 AM
Annihilator_X9's Avatar
Annihilator_X9
Gassers gotta keep O/D off when pulling. I've heard that diesels can pull in overdrive.
Old Mar 20, 2011 | 11:45 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Either way, seems like something is wrong. Why is it at 4000 rpm at that speed?
