Quick steering Stabilizer question
Old Mar 21, 2011 | 02:37 PM
95RAM360's Avatar
95RAM360
Default Quick steering Stabilizer question
ok i know my steering stabilizer is shot, cuz theres no resistance in it at all, and its original with a chewed up bushing......
1st question.....i need a puller to get it off right? or can i bang it out?
2nd question.....does it require an alignment afterwards?
Old Mar 21, 2011 | 04:01 PM
BamaRam97's Avatar
BamaRam97
I didn't use a puller to get mine off. As far as the alignment that is up to you but is always a good idea.
Old Mar 21, 2011 | 05:23 PM
DRP74's Avatar
DRP74
Don't need a puller. Just hit the bolts they will come out. No alignment needed. It has no adjustment to it. replace and go. If it's shot to where you had some steering shake when hitting a bump. then i'd get truck aligned.
Old Mar 21, 2011 | 09:03 PM
slicedtomatoes's Avatar
slicedtomatoes
also make sure you get a factory replacement or the oem one....when i did mine i bought an aftermarket with a bigger stabilizer/shock size and it didnt work ...it hit one of the tie rods...i cant remember the brand...my truck was a 97 ram 1500 4x4
