Trans cooler line problem
Old Mar 22, 2011 | 12:20 AM
CraZyNOTRT's Avatar
CraZyNOTRT
Default Trans cooler line problem
ok so my trans lines on my 99 dodge ram 1500 /w 5.9 were starting to leak. no biggy. bought some dorman replacement lines
624-304 return line
624-305 pressure line
pressure line went on without any problems.
But the return hose is being a pain in my @ss.
it will no clip on the return.
first one i bought had this problem so i tried to drill the hole a little deeper and screwed that hose up started leaking. o well 20 bucks down the drain.
bought another one. same problem will not click in to place.
its stopping short about 2 tenths of a inch short of clipping in to place. any info would be nice?
should i just suck it up and buy oem line?
or some how modify these to fit?
Old Mar 22, 2011 | 12:48 AM
dvowicker's Avatar
dvowicker
check to make sure there are no pre exsisting o-rings in there. take a small screwdriver and poke around
Old Mar 22, 2011 | 12:56 AM
CraZyNOTRT's Avatar
CraZyNOTRT
the new lines have a metal clip,some plastic peice(looks like a funnel), O-ring, spacer and another O-ring.
Old Mar 22, 2011 | 11:20 AM
Try twisting it a bit while you insert it. If that fails, see if the parts store carries a different brand......
