Window separated from motor?
Old Mar 23, 2011 | 10:44 PM
99redram318's Avatar
99redram318
Default Window separated from motor?
Hey guys haven't been on in a while, anyways my windows were froze stuck waited a bit to roll it down and its like the window separated from the motor/ rail thing. Is there any way to fix this or am I looking at buying a whole new unit? Thanks I appreciate it.
Mike
Old Mar 23, 2011 | 11:02 PM
Mine did that too..... I just pulled the door panel, put the glass back in the little bracket fellers, and called it good. I think there is some kind of adhesive you can use as well, and when I find out what it is, I'll pull the door back apart, and glue it back in there.
Old Mar 24, 2011 | 05:54 AM
95RAM360's Avatar
95RAM360
up all you need is a screwdriver and a 10mm socket....same happened to mine....the window came out of the adhesive black clips.....MAKE sure that windown dont drop down and shatter....cuz it wont land back on the track even if you have the motor all the way up.
