all types of axle questions
Old Mar 24, 2011 | 09:03 AM
95gaser360's Avatar
95gaser360
Default all types of axle questions
ok i have 1995 ram 2500 4x4. its the 8800lb version. i am wondering what gear ratio i have front and rear and if someone could explain what ratios are better for what and how they work
Old Mar 24, 2011 | 09:08 AM
pcfixerpro's Avatar
pcfixerpro
To find your ratio you can Request a build sheet (link available in faq section.) Check under your hood for a build sticker if you have one, or call dodge and look up your vin. There are also sometimes tags on a diff bolt. The ratio might be stamped on there as well.
http://www.howstuffworks.com/gears.htm
