99 ram 1500 5.9l cat issues/ CEL
Old Mar 24, 2011 | 05:54 PM
duvaldodge's Avatar
duvaldodge
Default 99 ram 1500 5.9l cat issues/ CEL
so recently ive been having power issues with my truck, such as during take off not having enough get up and go and such, well i started messing with my stock air-intake/breather made it so that it has a small space to get air from, right around where the breather clamps on, since then i believe i get better gas mileage and i know i have a very noticeable difference in power and get-up and go, i also took this time to clean almost all the sensors and plugs like: TPS, MAP, and IAC sensors. also i was having idle problems before, where it would irradically idle between high and low, since ive done these things its cleared up and idles perfectly, idk wether adjusting the breather or cleaning all sensors and things changed its performance, but after doing all this i got the check engine light and ran the codes got the catalyst 1/1 code p02040 or something or another, went to have my convertor cut out, turns out their isnt one in it, previous owner must have had it took out, but would like this code to go away. also after i had my new engine and comp installed a couple months ago my abs and brake light stayes on.
Old Mar 24, 2011 | 06:17 PM
You are allowing unfiltered air into the engine. Bad Plan. What does your air filter look like? From what you are describing, sounds like it is pretty dirty.....
Old Mar 25, 2011 | 02:43 PM
duvaldodge's Avatar
duvaldodge
I agree allowing unfiltered air into the engine is a very bad idea, that's kinda the reason they created air filters, my point was it runs great with the small gap ive made. and my air filter is perfect its a brand new k&n air filter. it just seems like it doesnt get enough air to the engine when it comes completly through the engine.
Old Mar 25, 2011 | 03:24 PM
Ok, my next suggestion was going to be: Look for the birds nest in your intake.... but, if you have been in there to change the filter..... I would like to think you would have noticed something like that.
Is it any better if you just take off the flex tube between the fender, and air box?
Old Mar 25, 2011 | 03:32 PM
duvaldodge's Avatar
duvaldodge
lol yes i would have seen it, i did a full body scan
and idk will test today, could it be that its not drawing enough air from outside the vehicle when its all hooked up correctly?
Old Mar 25, 2011 | 03:43 PM
It certainly acts like there is a restriction somewhere......
