intermitten ignition
ok so i have been fighting ignition problems lately. 95 ram1500 4x4 360 auto. has new from chrysler crank sensor, computer, and pick up coil. now i have no start again and i get a code 42 having something to do with the asd. help me out please.
ASD is a relay in the Power Distribution Center, right behind the battery, under the hood. They sometimes fail..... Swap the ASD relay with the wiper relay, and see if your truck will start. (and if it will, see if your wipers still work....)
there is no o2 sensor on the truck. never got around to putting another one in it. i have probed the plugs for the asd relay and that seems to be fine and have switched relays. one thing i have noticed is that occasionally i can put it in neutral and then back into park and it will start but not every time. could this be the ignition switch allowing it to crank but not powering the ignition?
