help?! replacing my dash and need info:)
Old Mar 27, 2011 | 11:06 PM
1500dodgeram318's Avatar
1500dodgeram318
Default help?! replacing my dash and need info:)
OK, so i have to replace my heater-core and thought since my whole dash has gotta come out i am just gonna replace the whole thing.
pretty much i need to know how to i am pretty good when it comes to working on cars but never really got into pulling a whole dash out. can someone give me the lowdown on how to do it i know there's bolts in the front but what else needs to come out.
any information will be greatly appreciated
also it is a 99 dodge ram 1500 reg cab short bed..
Old Mar 27, 2011 | 11:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
There is a DIY in the FAQ section.
You can also download the FSM from the FAQ section .
Old Mar 27, 2011 | 11:25 PM
PurplDodge's Avatar
PurplDodge
The service manual is pretty damn spot on. You can download the 2001 manual in the FAQ section.
My dad and I pulled out our dash in a day. Its as simple anyone with a brain can do it, just time consuming.
Old Mar 28, 2011 | 01:01 AM
99dodge318's Avatar
99dodge318
while your that far in, might as well dynamat the inside of the fire wall.
also isnt their and evaporator core or something behind the dash that usually goes out the same time as the heater core?
might as well do it all at one time
Old Mar 28, 2011 | 01:17 AM
steak59's Avatar
steak59
yeah, the Repair Manual will get you thru, your First time doing it will be VERY time consuming. when you are inside the Box, definite check the A/C evaporator core. And check all Blend doors, if one of them feels loose and flimsy, replace it.
My advice is Double Check and Triple check everything is back in place b4 u put the Box and Dash back together. I forgot an Air Duct AFTER i put EVERYTHING together once, it was a fun experience...
Old Mar 28, 2011 | 06:36 AM
PurplDodge's Avatar
PurplDodge
There is a really nice, thick sheet of insulation with a rubber type covering. No Dynamat needed. The doors, floor, roof, and back wall are what need it.
Yes, take apart the HVAC box, clean it, and reinstall with a new heater core and evaporator core. Do it or regret it.
