leveling kit, HIDs.. off topic shaking?
Old Mar 28, 2011 | 05:57 PM
tatitup8's Avatar
tatitup8
Default leveling kit, HIDs.. off topic shaking?
Finally ordered my 2" leveling kit and going to get some HIDs..
does anyone have a picture of a dodge with nothing but a 2" leveling kit on it for a 2wd? im just curious to see what it's going to look like.. also how far out of alignment will it put me?
HIDs: i can't decide how i want to do this... i talked to a guy at a local custom shop and he said not to do both low and high? he said when you turn from your lows to your highs, the high takes a few seconds to turn on because of "warmth" or something? anyone have more info on this? also what "k" should i get? ive been looking at the 10000k..
this is off topic, but when i drive down the road, when i get to 65mph, the truck starts to shake a little, but it'll stop when i get to 70? anyone know what this is?
99 dodge ram 1500 2wd 5.2 318
Old Mar 28, 2011 | 06:19 PM
Ram_King's Avatar
Ram_King
for the hids, ive got a pair of hids off of amazon for 35$ hi/lo 12k work great i have never had a problem with the high beams not turning on, and they cam with 3 yr warrenty on the converter box, and 1 yr on the bulbs them self. And as for the shaking go and have your tires re balanced, i had the same problem and it fixed the prob, might not be the same situation as you but a good start.
Old Mar 29, 2011 | 05:35 PM
99redram318's Avatar
99redram318
I got 8k heads and fogs and love them! No need for high beams aren't necessary. You can find all kinds of deals online for H.I.D.'s Customelements.com is legit and its my buddies company
Old Mar 29, 2011 | 05:48 PM
97Rampowerhouse's Avatar
97Rampowerhouse
not sure Ive ever seen a 2 inch leveling kit on 2wd most guys drop em
Old Mar 29, 2011 | 07:04 PM
redheadhunter21's Avatar
redheadhunter21
Leveling up or down, and hids start with just the low beams and if you decide to get the high beams you can order them later, and all hids have a warmup time takes a couple seconds, dont know if that would stop me from gettin them for high beams
Here is a thread to look at for a leveling kit with raising the front(1.5" though)
https://dodgeforum.com/forum/2nd-gen...hat-i-did.html
Old Mar 29, 2011 | 08:34 PM
jasonw's Avatar
jasonw
Site Moderator
HIDs need to be done properly. HIDs in the stock headlamp assemblies will blind people and are technically illegal. If they are so bright you don't need high beams, that should be your first clue.
You need a headlamp with some kind of shield, like some of the newer models have, with a proper beam cutoff, to even begin to do it properly. Even better would be projectors. Thats number one.
Number two, the most you want for visibility is 6000k. 5000k-ish or so is best. Anything above those, you actually lose visibility (due to the fact that our eyes see more with white or yellow light, not blue or above), and its just for looks. It may look like you can see further with bluer light, but its just a trick of the eyes.
I hate to bust some people's bubbles here, but there you are.
Old Mar 29, 2011 | 09:05 PM
BigRedRam95's Avatar
BigRedRam95
My dad has a set of low/high hid in his truck 5000K and they flip up to high fine. I have a set of 10000k low and I like his better than mine not because they are alot brighter I just like the looks of his better
Old Mar 29, 2011 | 09:35 PM
tatitup8's Avatar
tatitup8
the leveling kit is already ordered and putting it on thursday, as for the HIDs i think i'm goin to order some 10000k or 12000k.. not so much for "seeing better" but for looks.. they will be brighter than my projectors now, and they will look better. i like the bluer lights alot.. but no matter which one i get it will increase visibility.. and yes it's an aftermarket headlight assembly with the halo and projector.
Old Mar 30, 2011 | 02:43 AM
awramit's Avatar
awramit
My truck has 3" spring spacers (only gave me about 2.5) but I do have 3" blocks on the back.
