plenum question
Old Mar 31, 2011 | 02:59 PM
MedicNathan's Avatar
MedicNathan
Default plenum question
So a question, if you aren't really going through oil (half a quart in 3500 miles) can you have a blown plenum? it was my understanding that plenum leaks caused you to leak oil like a ****
Old Mar 31, 2011 | 03:02 PM
They can, and excessive oil consumption is indeed a sure sign of a blown plenum. Your oil consumption is pretty normal for an old truck though. Have you looked down your throttle body to see what things look like?
97Rampowerhouse's Avatar
97Rampowerhouse
lack of power?
Old Mar 31, 2011 | 03:31 PM
MedicNathan
How much power is a truck with 145k miles supposed to have? I haven't really hit the throttle hard enough recently or towed anything to noticed one way or the other. I may have lost some. When i swapped the TB in january the intake was jet black inside. If i look again what should I be looking for.
Old Mar 31, 2011 | 03:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Oil, use a small mirror and a light to look all around inside.
Old Mar 31, 2011 | 03:49 PM
MedicNathan
Will check tommorrow when I get it in the shop. I forgot to say that my concern is that my economy droped from 17-18 highway to 12. This was after a major tune up. prior to this I was getting 13 - 14 highway.
Old Mar 31, 2011 | 04:20 PM
97Rampowerhouse
145,000 miles is not a huge amount if the motor was taken care of you should still have the same amount of power from when it was new
