End-all Be-all plenum thread
Old Feb 20, 2012 | 07:08 PM
  #271
gdstock's Avatar
gdstock
Scotchbrite will clean that surface pretty well also. Auto parts store in paint section.
Old Feb 20, 2012 | 07:21 PM
  #272
bwdakrt's Avatar
bwdakrt
Originally Posted by cutthroatxxx
Aye so what about that torque wrench only going down to 20 when your suppose to start off@12?Do I just get close?
I've never torqued any belly pan bolts just tighten until real snug but always did it in the proper sequence. If torquing is a major concern, you can rent a inch pound torque wrench at any AZ.
Old Feb 21, 2012 | 06:57 AM
  #273
dacheedah's Avatar
dacheedah
Just finished my truck and it took me about 10 hours. I did buy a torque wrench from Harbor Freight for $15.00 that does inch pounds.
http://www.harborfreight.com/1-4-qua...ench-2696.html
Old Feb 21, 2012 | 12:24 PM
  #274
cutthroatxxx's Avatar
cutthroatxxx
Yeah thats what I was thinking...Autozone only has em that start off@20 inch lbs just like the harborfreight one.So youd be skipping a step if you did it by spec.Ill figure it out.Just had my kid yesterday si Ill be tackling my pan next week.
Old Feb 21, 2012 | 12:30 PM
  #275
i mow grass's Avatar
i mow grass
Finally got my intake clean yesterday, and the last broken bolt out! Few questions about my intake though, I noticed some pitting in the intake. Will this pose a problem or will the gasket+rtv do the trick or am I screwed? Also does this look clean enough for me to use?
(You should be able to click to make view bigger)
Again, sorry for all the questions on this I am just trying to get it done right the first time, and I am sure I will have many more questions before I finish it.
Old Feb 21, 2012 | 12:34 PM
  #276
Nereaga's Avatar
Nereaga
Congrats! Buckle up! Gonna be a bump ride...
Old Feb 21, 2012 | 12:44 PM
  #277
Pitting around coolant ports is fairly standard, and can be dealt with by the RTV.
I would buff 'em a bit more, but, I am picky.... (paranoid?)
Old Feb 21, 2012 | 12:58 PM
  #278
i mow grass
Well Northern Tool only has brass coated steel brushes so I got paranoid when i saw a few specks of aluminum that I would start taking aluminum off if I continued. ScotchBrite here I come!
Old Feb 21, 2012 | 04:01 PM
  #279
zman17's Avatar
zman17
Retired Moderator - RIP
Hopefully you are reading instructions from either one of the free FSM downloads in the FAQ/DIY section or a Haynes (and not just relying on info you get in your threads here). Because if you are reading one of the manuals , you will see that both say to put a small amount of rtv on both sides of the intake gaskets around the coolant ports only.
Old Feb 21, 2012 | 04:14 PM
  #280
cutthroatxxx
Thanks we got a 1 yr old&the new one no time for nothing
