Additives...Do they work?
Old Apr 4, 2011 | 10:26 AM
  #21
aim4squirrels's Avatar
aim4squirrels
Originally Posted by charlie1935
I suppose no one uses water to clean the carbon out any more.
Years ago we just filled a soda bottle with water and let it dribble into the carb while keeping the motor revved up.
It worked but the chemicals they use now days may do it better and quicker.
That method still works and write well, I think its mostly advertising and a fear of putting water in an engine that most cower away from.
Old Apr 4, 2011 | 03:11 PM
  #22
PurplDodge's Avatar
PurplDodge
Originally Posted by Novarider
Hmmmmm ok. What line is used on a 2000 5.9? Also would it be bad to use it if the plenum is blown?
One more thing. How did you put it in your mower? My rider could use a good cleaning
The brake booster cable. Goes from the driver's side intake manifold to the brake booster assembly (the big round black thing). Pull the hose off at the booster and pour in after reading the Seafoam instructions.
What kind of riding mower do you have? Basically take off the air filter and pour the Seafoam into the carburator.
Old Apr 4, 2011 | 03:38 PM
  #23
Novarider's Avatar
Novarider
It's a craftsman riding mower. I bought it used and the guy told me he used it to cut down some trees that were slightly larger than a quarter (the coin not the measurement) in size. It still runs pretty good tho.
So I just pour it into the carb huh? I will have to give that a try
Would it be bad to use on my truck if my plenum is blown?
Old Apr 4, 2011 | 04:12 PM
  #24
PurplDodge's Avatar
PurplDodge
No, not really. But when you fix your plenum you should do it again.
Old Apr 4, 2011 | 04:18 PM
  #25
Novarider's Avatar
Novarider
Ok. Just wanted to make sure it wouldn't hurt anything
