Recharging a/c
Old Apr 3, 2011 | 07:23 PM
DodgeRam10's Avatar
DodgeRam10
Default Recharging a/c
is there a special adapter required for dodge a/c systems? i went to charge it today and the hose wont fit on the low side the low side port is too big. it fits on the high side line just fine but not the low side. the a/c kit came with an adapter but the end that threads on to the existing port is a female thread and the existing port has threads on the inside so the adapter would have to be a male thread. is this makin sense?
Old Apr 3, 2011 | 07:29 PM
mdavis735's Avatar
mdavis735
Are you positive the two aren't mixed up?the low side should be the smaller of the two.
Old Apr 3, 2011 | 07:30 PM
DodgeRam10's Avatar
DodgeRam10
the low side goes from the accumulator to the compressor right
Old Apr 3, 2011 | 07:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The low side is the small one closest to the accumulator (firewall).
Old Apr 3, 2011 | 07:35 PM
DodgeRam10's Avatar
DodgeRam10
when i hooked it up to the small line that runs to the condensor the gauge was in the red zone and the psi was like 130 or something. i checked in the manuel and i thought it said the suction line was connected to the accumilater
Old Apr 3, 2011 | 07:40 PM
DodgeRam10's Avatar
DodgeRam10
if you get the service manual from this site and go to chapter 24(heating and air conditioning) and go to the paragraph that says"
OPERATION - REFRIGERANT SYSTEM SERVICE
PORT" it says the high side is near the front of the motor and the low side is off the accumulator.
Old Apr 3, 2011 | 07:44 PM
zman17's Avatar
zman17
Yea, that's what I said. The can and hose you buy at the store will only attach to the low side. I hope you are wearing eye protection and gloves.
Old Apr 3, 2011 | 07:47 PM
DodgeRam10's Avatar
DodgeRam10
you said the low side is closest to the firewall, the manual says the high side is next to the firewall and the low side is on the line going from the accumulator which runs to the compressor.
Old Apr 3, 2011 | 07:49 PM
DodgeRam10's Avatar
DodgeRam10
sorry i see what your saying but on my dodge the fat line goes from the accumulator to the compressor and the small line runs along the frame to the front of the truck into the condensor from the evap.
Old Apr 3, 2011 | 07:54 PM
zman17's Avatar
zman17
The port that is closest to the accum/ or firewall is the low side, simple as that. I take it the plastic caps are missing?
