Cylinders 4 and 8 not firing
Old Apr 4, 2011 | 01:47 PM
YJMike's Avatar
YJMike
Are the injectors firing? I know you swapped 'em around, but, if the PCM doesn't fire them, for whatever reason...... swapping them around won't help.
Never thought about the PCM, im going to get it scoped today to see whats up, ill get them to do a compression test also, will i be able to get away with the just reflashing the PCM if that is the issue?
Old Apr 4, 2011 | 01:49 PM
I was thinking more along the lines of a wiring issue. If the PCM has an internal open circuit..... re-flashing won't fix that.
Let us know what they have to say.
Old Apr 4, 2011 | 05:26 PM
YJMike's Avatar
YJMike
no compression is the issue, so its time for a motor....one cylander has blowby at the valves and it appears the rings are fried on the other.....i know where i can get a 318 out of a 2OOO ram, what would i have to do to make it compatible with my 94'
Old Apr 4, 2011 | 05:59 PM
Mad_Scientist's Avatar
Mad_Scientist
You'd have to swap out the intake mani to accommodate all of the sensors... I think thats it.
Old Apr 4, 2011 | 07:52 PM
YJMike's Avatar
YJMike
im not going to have any comp. issues?
Old Apr 4, 2011 | 08:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Not as long as you swap the intake.
Old Apr 4, 2011 | 08:02 PM
Mad_Scientist
Not so long as you get every sensor in there that the pcm wants (which is why the intake swap is necessary... There are more sensors/holes on a 94 intake than on a 2000). Other than that, I believe the engines are the same.
EDIT:LOL, zman ninja'ed me
Old Apr 4, 2011 | 11:24 PM
YJMike's Avatar
YJMike
awesome, thanks for all tghe help guys
