Spark Plugs
Old Apr 5, 2011 | 10:30 PM
Seth_787446's Avatar
Seth_787446
Default Spark Plugs
On the 5.9L V8 is the drive size a 5/8" or 3/8"?
Also, what should I do if the bolts are soo rusted they won't come out?
The heat shields are still attached by the way.
Old Apr 5, 2011 | 10:34 PM
PurplDodge's Avatar
PurplDodge
5/8''.
PB Blaster.
Old Apr 5, 2011 | 10:54 PM
JSTMoto's Avatar
JSTMoto
What he said, and take a compressor to blow the dirt that gets trapped by the heat shields. Take a blow gun and blow around the plug before you take it out. Use anti-seize on the new plugs before you install them. It's sold at auto parts stores.
Not required, but worth the extra 2 minutes.
-JT
Old Apr 6, 2011 | 12:01 AM
slayer45065's Avatar
slayer45065
Before you pull out the old plugs you could rip out the heat sheilds. Took me about an hour with vise grips.
Old Apr 6, 2011 | 12:06 AM
UnregisteredUser's Avatar
UnregisteredUser
And if I might add my three-eighths of a cent worth:
Blow the crap out of the heat shields before applying the penetrating lubricant so you don't make mud.
Anti-seize should be considered mandatory. It's easier to apply anti-seize today than to extract a broken plug during the next tune-up.
If any of the plugs are difficult to remove, grind on the way out, or show rust on their threads, chase the threads (in the head) with a thread chaser (not a tap).
Old Apr 6, 2011 | 12:17 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Also torque them to the proper spec and you'll never have a problem replacing them in the future.
