My temp runs high...
Old Apr 6, 2011 | 06:15 PM
7KINGKAOS7's Avatar
7KINGKAOS7
Question My temp runs high...
I'm gauge reads between 205 n 210 at running temp... Is this normal for these trucks?
Thanx
Old Apr 6, 2011 | 06:18 PM
jasonw's Avatar
jasonw
Site Moderator
No. Factory thermostat is 195, it should be around that.
How is the coolant level?
Old Apr 6, 2011 | 06:25 PM
7KINGKAOS7's Avatar
7KINGKAOS7
I have a small coolant leak around the neck on the engine.
Old Apr 6, 2011 | 06:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Well fix it then, and flush system while it's apart, and see if it runs a little cooler.
Old Apr 6, 2011 | 09:32 PM
TryMeImHard's Avatar
TryMeImHard
fix the leak flush and put new coolant make sure nothing is covering your radiator, although ac condenser is in front still might not be cooling right.. mine was covered in mud and i was running a few degrees above normal
Old Apr 7, 2011 | 07:00 PM
Buellstunter's Avatar
Buellstunter
My truck runs about the same temp. aprox. 205-210. been that way since I bought it. backflushed cooling system, new temp sensor,thermastat (195)deg. still stays the same. I assumed the gauge was just off a little
Old Apr 7, 2011 | 07:10 PM
96magnumram's Avatar
96magnumram
Mine runs straight up on 200 going down the road...while sitting it will get to like 205 for about 40 or so seconds while sitting at a red light. It's always done that though...
Old Apr 7, 2011 | 09:31 PM
redheadhunter21's Avatar
redheadhunter21
Mine ran around 210 then I put a gallon of water in it and now its back to around 180-190.
Seems a tad high would make sure it is full with no air pockets.
Old Apr 8, 2011 | 02:09 AM
jasonw's Avatar
jasonw
Site Moderator
Yup, definitely not normal guys.
Before my electric fans or 180 thermostat, with a wobbly clutch fan, I'd get to 200, absolute max, on a hot summer day with the A/C on full blast.
