Help!!!! Hood won't latch
Old Apr 8, 2011 | 11:16 AM
cougardoug's Avatar
cougardoug
Default Help!!!! Hood won't latch
So this moring I changed the oil in my truck, finished the job and went to shut the hood and and go for a drive. The hood will not latch. The latch that you use after the pulling the lever inside the truck is latching but the main latch is not working. Any ideas on how to fix this?
Old Apr 8, 2011 | 11:50 AM
BamaRam97's Avatar
BamaRam97
Check the service bulletins in the FAQ section. I think there was a recall/TSB for the hood latch on some models.
Old Apr 8, 2011 | 12:11 PM
That was for the secondary hood latch I think.
Check the latch, and make sure the locking lever hasn't just stuck in place. I think there is a spring on it.... but, not 100%.
Old Apr 8, 2011 | 12:34 PM
alegar's Avatar
alegar
Yeah probably just a lever stuck check the lever where the hood pop wire attaches they love to hang up. Just lube it up and get a screw driver in there and push it back.
Old Apr 12, 2011 | 12:06 AM
03neonSE's Avatar
03neonSE
Use PB Blaster to free it up then use WD-40 to keep it free. Thats what i've done and never had an issue so far.
Old Apr 12, 2011 | 03:49 AM
TryMeImHard's Avatar
TryMeImHard
Did you try pulling hood release again?? might of just hit funky and latch closed??
Old Apr 16, 2011 | 01:32 PM
wilfite's Avatar
wilfite
I seem to remember a little plastic part that holds one of the metal rods in place. I dropped mine when changing my grill and the hood didn't latch. I used some electrical tape as a short term fix to replace the little plastic clamp, but it's working so well I've not gone back to fix it right in at least a year.
