Factory amp
Old Apr 21, 2011 | 01:00 AM
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by redheadhunter21
there is also amps on the rear speakers
Not in the later model years there aren't. Not sure on 1998 though.
Old Apr 21, 2011 | 01:49 AM
redheadhunter21's Avatar
redheadhunter21
All I can tell you is my 96 had them on the rear speakers, I was surprized to see them when I pulled the panel off
Old Apr 21, 2011 | 07:10 AM
Novarider's Avatar
Novarider
There were no amps on my rear door speakers of my 2000
Old Apr 21, 2011 | 08:42 AM
gipperkid's Avatar
gipperkid
Correct, the rears do not have amps. The rear speakers get power from the fronts. Because when the front speaker is disconnected, the rear speakers do not work.
Old Apr 21, 2011 | 12:29 PM
redheadhunter21
I got a question for you newer trucks, were your rear speakers 2-way speakers and what size are they, I'm wondering if they dropped the rear amps when they added the doors
Old Apr 22, 2011 | 12:13 PM
dan64779's Avatar
dan64779
my 98 has the extended cab and it has 5 1/4s in the rear doors
Old Apr 22, 2011 | 12:34 PM
CappinHoff's Avatar
CappinHoff
2000 rams can use these speaker sizes.
Front
5-1/4(only with mounting bracket)
6-1/2(only with mounting bracket)
6x9
Rear
5-1/4
6-1/2(re-drill of mounting holes are needed)
6-3/4(re-drill of mounting holes are needed)
These also are the same for 98-2001.
Old Apr 23, 2011 | 02:48 PM
dan64779's Avatar
dan64779
my 98 has 5 1/4s in the rear and the front are 6 by 9s
