Weak spark
Old Apr 9, 2011 | 07:34 PM
kikidbird's Avatar
kikidbird
Default Weak spark
I did an OH on my engine and now it does not want to start. I've been checking all my wires and connections and nothing. I do not have spark at the end of the spark plug wires. I do have a weak spark at the coil. When I'm cranking it over, it takes a brief second for the small spark to occur. Shouldn't the spark be strong and constant? I have changed the cap/rotor, spark plug wires and the coil. I'm wondering if my PCM is bad. Any Ideas?
Old Apr 9, 2011 | 08:59 PM
Hahns5.2's Avatar
Hahns5.2
It's the coil.
Had the same thing happen. Had OK spark directly on the coil wire but nothing out of the distributor.
Old Apr 9, 2011 | 09:06 PM
drewactual's Avatar
drewactual
Is your coil yellow?
Old Apr 10, 2011 | 08:19 AM
charlie1935's Avatar
charlie1935
I had one of them yaller ones, now have a red'n.
Old Apr 10, 2011 | 10:12 AM
kikidbird's Avatar
kikidbird
It is Red MSD Coil. I checked the resistance and it is within specs. I installed the OG coil and it is the same thing, i also checked the resistance per OEM Manual and it is within specs. If my "Pickup Coil" was bad would I still get spark?
Old Apr 10, 2011 | 10:16 AM
kikidbird's Avatar
kikidbird
Was it a cold weak and inconsistent spark?
Old Apr 11, 2011 | 11:30 PM
kikidbird's Avatar
kikidbird
I replaced the coil and still have the same problem.
