Underdrive pulleys
Old Apr 10, 2011 | 11:01 PM
281-318magnum's Avatar
281-318magnum
Default Underdrive pulleys
I installed my Underdrive pulleys today, changed the crank case and alt. lost so alt. power but it ok i don't use much elec.and while I was under the hood I cut the wings off my throttle body made a decent improvement to me. Well those who are looking to get the pulleys the new belt size will be 15/16" x 95-3/4". I got the gates belt part # K070951
Old Apr 10, 2011 | 11:10 PM
281-318magnum
You have to use a impact gun socket size 7/8" to remove the alternator nut. the crankcase socket size is 1/2" if I remember correct.
Old Apr 10, 2011 | 11:36 PM
PurplDodge's Avatar
PurplDodge
Ha!
The loss of power to my accessories is one reason why I wont get underdrive pulleys. The 7 or so horsepower "freed-up" from underdrive pulleys is not worth it to me.
Old Apr 11, 2011 | 12:03 AM
rl99dram's Avatar
rl99dram
Sweet thanks for the info.. ive got no extra electirc really needed plus im gettin a bigger alt here soon so this will be nice. haha.
Old Apr 11, 2011 | 01:01 AM
99dodge318's Avatar
99dodge318
so if you used a bigger alt with the underdrive pullys, would it equal everything out?
ive been wanting to install some when i do my e-fan
Old Apr 11, 2011 | 06:13 AM
dipsherry's Avatar
dipsherry
i have just the crank pulley i have efans and a stereo. No problems unless my lights are on and fans running also with stereo cranked up then yes my voltage is below 14 at idle
Old Apr 11, 2011 | 01:38 PM
rl99dram's Avatar
rl99dram
So is crank and underdrive pulley the same thing? and where do you purchase these pulleys?
Old Apr 11, 2011 | 03:39 PM
saleen288's Avatar
saleen288
Here ya go!
http://www.hughesengines.com/Index/p...1=UHVsbGV5cw==
Old Apr 11, 2011 | 03:44 PM
PurplDodge's Avatar
PurplDodge
The crank pulley is the pulley on the crankshaft. Underdrive pulleys slow down the accesories (underdrive) and and free up horsepower.
ASP makes underdrive pulleys:
http://www.aspracing.com/mopar.htm
Old Apr 11, 2011 | 03:59 PM
rl99dram's Avatar
rl99dram
I used common sence for the crank pulley haha thanks though, and thanks for the sights and explanations help appreciated.
