magically disappearing coolant
Old Apr 13, 2011 | 02:01 AM
kccisco's Avatar
kccisco
FOUND IT!!!!! it was the water pump, what it would do was it would trickle at low rpms so the motor and heat in the engine bay would evap the coolant away so that i couldnt see it but at higher rpms the leak would flow pretty heavily. as a side note i could kill an engineer for makeing the inlet hose so short and having it incased by the motor so that you cant get a any grip on it to slide the new pump on easily (fought for an hr getting it back on with the gasket in place only to realise i didnt have the clamp on it so i said **** it and slapped a hose clamp on it insted)
Old Apr 13, 2011 | 02:21 AM
97tn4x4's Avatar
97tn4x4
You didn't take the accessory bracket off?
Old Apr 13, 2011 | 08:37 AM
alegar's Avatar
alegar
Sweet deal, glad to hear you got her fixed back up.
Old Apr 13, 2011 | 01:46 PM
kccisco's Avatar
kccisco
nop i left the bracket on thinking it would be less time consuming to deal with it
Old Apr 13, 2011 | 02:10 PM
Annihilator_X9's Avatar
Annihilator_X9
That hose is impossible. I'd take the bracket off. In fact, that inlet hose was about to burst on mine. Glad I saw that when I did my plenum. Why did they hide that damn thing?
Old Apr 13, 2011 | 06:55 PM
Because engineers hate mechanics.
Old Apr 13, 2011 | 08:55 PM
jeff351's Avatar
jeff351
my coolant tank had a crack on it, right at the tab where it slides into the radiator shroud. I took it off, cleaned it up, and patched it with JB Weld on the inside and outside of the area cracked. No more leak.
Old Apr 13, 2011 | 09:08 PM
Mad_Scientist's Avatar
Mad_Scientist
I too have had hard times with that damn hose... I swear, the engineers should have had it cast (formed, molded, whatever) with a middle finger emblem on it and text that read "changing the water pump huh? F U, you should've taken it to the dealer"
The same goes for those spring loaded band clamp things... or as I like to call them, eff you clamps
@ OP: glad you got her fixed.
