99 ram 2500 5.9L 4x4 getting 8mpg HELP!!!
Old Apr 22, 2011 | 10:48 PM
  #21
articsilber323's Avatar
articsilber323
Higher the vacuum, better the mileage.
Have a look down your throttle body, just to be sure.
does the smell get worse when you turn on the heater? any evidence of leaks anywhere?
Clean the remaining stock pulleys. A bit of dirt makes a lot of noise.
i will double check the plenum ,
no sign of leaks anywhere at all everything is bone dry, and smell starts about when belt starts making noise after everything has been running 10-20 minuts and never goes away till the next day
Old Apr 22, 2011 | 11:12 PM
  #22
slayer45065's Avatar
slayer45065
Take off your belt and make sure all of your accessories are spinning freely. You might have a bearing seizing up.
