What is this leaking?
Old Apr 12, 2011 | 04:40 PM
  #21
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by 99dodge318
"...would you like to buy some fuel injector..."
to which i cut him off and reply;
"HELL NO! i buy that stuff by the gallon!"
I say almost the same thing: "Nah, I run Chevron fuel". Every now and then I end up having to explain it. I miss the old days when you could walk into a NAPA and the counterman actually knew something.
Old Apr 12, 2011 | 06:36 PM
  #22
Seth_787446's Avatar
Seth_787446
Originally Posted by dhvaughan
as said a small amount of gear lube will come out of the cad when you remove it. 1 or 2 cups. the factory gasket is a fancy cork/aluminum thing. mine was a little confusing because i could see the cork and kept scraping at it, and didn't see the thin aluminum backing plate that needed to be pried loose.
Where do I need to add the 2 cups of fluid that comes out of the CAD? Just add it into the front diff?
Old Apr 12, 2011 | 06:44 PM
  #23
97tn4x4's Avatar
97tn4x4
All I do is fill the front diff, take it for a drive and check it again.
Old Apr 12, 2011 | 07:21 PM
  #24
dhvaughan's Avatar
dhvaughan
just refill the front diff up to, or just below, the fill hole.
if its full, or close to full, that cupful will never be missed.
having the front diff completely full can cause some oil leaking past weak seals.
some people intentionally run it just a tad low, not much, to reduce leaks.
Old Apr 12, 2011 | 07:25 PM
  #25
Seth_787446
Cool thanks! I will more than likely fix this weekend and have pics up. One more thing, is 85W-140 ok to use? Lucas Oil brand good or bad for front diff?
Old Apr 12, 2011 | 08:08 PM
  #26
dhvaughan's Avatar
dhvaughan
any GL5 rated gear oil is fine (which is all of them).
gear oil is damned expensive, so if you can find it by the gallon for a decent price it might save you a lot of money. front and rear diff's take about 2.5 quarts each to refill.
its a good idea to change it regularly, especially if you drive in water. my front seals use to leak and it would get water in it, which is very very bad....
Old Apr 12, 2011 | 08:31 PM
  #27
97tn4x4's Avatar
97tn4x4
85w140 should be fine. It's certainly cheaper than 75w140, it's like 12 bucks a quart. To me gear oil is gear oil I don't really use a certain brand. Whichever one is cheapest really.
Old Apr 12, 2011 | 09:04 PM
  #28
dhvaughan's Avatar
dhvaughan
i think i saw a 1 gallon jug of house brand gear oil at walmart, but i can't remember the price. i wouldn't be afraid to use it.
anyone know the price of it?
SUPER TECH 75W140 SYNTHETIC GEAR OIL -- WARREN DISTRIBUTION
SUPER TECH AND TECH 2000 GL-5 SAE 80W90 GEAR OIL -- WARREN DIST
SUPER TECH AND TECH 2000 GL-5 85W140 GEAR OIL -- WARREN DISTRIBUT
Old Apr 12, 2011 | 10:19 PM
  #29
Seth_787446
I was at Wal-Mart today and all they had was 85W-140 I didn't see any 75W
Old Apr 13, 2011 | 04:10 PM
  #30
Seth_787446
So I picked up 1 gallon of Super Tech 85W-140 it is GL-5 so it will work, was about $14 after tax, or I could have bought 1 quart for $5
