What is this leaking?
Old Apr 11, 2011 | 10:23 PM
Seth_787446's Avatar
Seth_787446
Default What is this leaking?
Old Apr 11, 2011 | 10:26 PM
dhvaughan's Avatar
dhvaughan
that's the CAD. central axle disconnect. passenger side of front axle.
you can remove it and reseal it with RTV.
spray some penetrating oil on the bolts for a couple of days. they like to snap off.
Old Apr 11, 2011 | 10:35 PM
Seth_787446
Once I get it off is there something I'm suppose to do to it? Like a gasket or sealant or what?
Old Apr 11, 2011 | 10:36 PM
Mad_Scientist's Avatar
Mad_Scientist
^^^^What he said... Keep your diff topped off in the mean time (80-90 weight gear oil). Definitely don't want to run that sucker dry or you'll be rebuilding it next.
Soak the bolts with pb blaster or the like beforehand to ensure that they dont break off.
Old Apr 11, 2011 | 10:41 PM
Seth_787446
Oh sorry must have over read that, what is RTV?
Old Apr 11, 2011 | 10:42 PM
Mad_Scientist
They make a gasket for it, but I usually use RTV blue (silicone gasket maker).
RTV and duct tape could hold the world together.
Clean both surfaces thoroughly and lay a bead of RTV around them (encircle the bolt holes). Put her back together and wait 12-24hrs for it to cure. Then check for leaks and top off the diff. Done.
Oh, and keep in mind that some gear oil will inevitably spill out when you take it off, so have a bucket handy.
Old Apr 11, 2011 | 10:44 PM
97tn4x4's Avatar
97tn4x4
The front diff is supposed to take 75 140 gear oil.
Mad_Scientist
RTV= room temperature vulcanizing.... fancy way of saying it turns from a liquid to solid silicone at room temp. You'll want the blue kind for this application.
Old Apr 11, 2011 | 10:46 PM
Mad_Scientist
Pretty sure it's 80-90... but I could be wrong. Ask the guy at the parts counter.
Old Apr 11, 2011 | 11:11 PM
PurplDodge's Avatar
PurplDodge
I cant even get the guy at my Advance Auto to get me a NGK spark plug for my mower, how do you expect them to give him the right fluid? The dumbass would probably tell him to go get some Type-F transmission fluid.
The correct fluid is 75W-140 synthetic. Change it and the rear fluid while you are doing the gasket.
https://dodgeforum.com/forum/2nd-gen...uid-types.html
