New to forum and need some help
Old Apr 12, 2011 | 08:46 PM
Hiddenredneck's Avatar
Hiddenredneck
Default New to forum and need some help
Bought a 98 1500 4x4 5.9 last year. It has 200+ on it and runs great, except I had to replace the alternator last summer. Since then the battery wont hold a charge and I have had everything tested. Every time I try and start it, I have to jump it to get it going. Then the battery still won't hold a charge. Any advice would help, I have tested everything. The alternator is good and battery is brand new, the second one after I killed the first one for the same issue. Anyone else had a problem similar to this? I can't think of anything that would be draining the battery. Thanks in advance.
Old Apr 12, 2011 | 08:58 PM
TryMeImHard's Avatar
TryMeImHard
is alternator hooked up right?? does it start again right after you shut it off or does battery slowly drain over night??
Old Apr 13, 2011 | 02:50 AM
TryMeImHard
well just another thing i dont think anything on your truck would possibly drain battery faster than it charges... check charging system
