Grinding in third only?!
Old Apr 13, 2011 | 04:49 AM
Jeremy71655's Avatar
Jeremy71655
Default Grinding in third only?!
Hey guys! new to this forum but I need some help. I tried searching but nothing came up sooo. I have a 99 2500 standard shift. When I shift into third upshift or down shift, I get a grind as if the clutch isn't engaged. I can double clutch and sometimes it will go away but its doing it in third gear only! I was thinking a syncro but I'm not sure. Any ideas?
Old Apr 13, 2011 | 04:56 AM
97tn4x4's Avatar
97tn4x4
Syncro sounds like very good possibility.
Old Apr 13, 2011 | 05:07 AM
Jeremy71655
thanks I figured that might be the case!
