Larger shackle, will that lower the truck?
Old Apr 14, 2011 | 01:13 AM
95RAM360's Avatar
95RAM360
Default Larger shackle, will that lower the truck?
got a quick question.
I found some shackles that will fit my truck that are about twice as long as the stock shackles, but it says lowering shackles on the box...
Now would a larger shackle give me less height? this is puzzling me....to me it seems id get more height.
if this is the case, i will only put it on the drivers side, because the shackle is 2 1/4in longer then the stock shackles, and my drivers side sags about 2 in more then passenger....i thought this would be good since its only 30 bucks for the pair.
Old Apr 14, 2011 | 01:22 AM
Mad_Scientist's Avatar
Mad_Scientist
The shackles are flipped up when stock, so a longer shackle=leafspring goes up towards the bed=axle closer to top of wheel well
Simpler definition: it would put the ends of the leafsprings closer to the bed, which tucks them further into the bed, thus moving the axle further up.... if that makes any sense at all... too many beers... yes, it will lower it
Old Apr 14, 2011 | 01:27 AM
95RAM360's Avatar
95RAM360
alright good to know, thanks
Old Apr 14, 2011 | 08:24 AM
EndIsNear's Avatar
EndIsNear
Flip the hanger. Then it will lift it
Old Apr 14, 2011 | 10:23 AM
95RAM360's Avatar
95RAM360
i remember reading a thread that with flipping it, it can move the axle...will that be an issue in my situation? or will it move the axle a little, and no harm will be done?
Old Apr 14, 2011 | 10:27 AM
EndIsNear's Avatar
EndIsNear
It does move the axle. I flipped mine, but used stock shackles and it moved forward a hair. With lift shackles, it will move considerably more. But a $40 zero-rate block kit can solve the problem if it concerns you.
