ball joint stretching
Old Apr 15, 2011 | 10:14 PM
smcandrew08's Avatar
smcandrew08
Default ball joint stretching
Hey guys i wanted to know what ball joint stretching was. I had to replace the lower joint a few days ago but i never replaced the top one. They were both new but long story short i broke a wheel off because i didnt have the stub shaft in so the hub came apart... Anyway i replaced what was broken and put the top ball joint back in. I saw on here someone said that is the wrong this to do because it is stretched out or something. Well my front axle is making a low noise now (kinda like a hub is going out but the hub is good) and the brakes feel different, not mushy but sensitive? Anyway i wanted to see if not replacing the top ball joint could be the problem?
EDIT: Do i have to have the brake dust sheilds on both sides? I dont have them on the driverside where the noise is coming from, is that messing with clearances in the pumpkin?
Old Apr 16, 2011 | 10:57 AM
Ball joint stretching? Never heard of it..... the holes they go thru can get ovaled, but, that would be fairly obvious. I have pulled hubs, etc, many times without replacing balljoints. (front wheel drive cars for axle replacement for instance.) If you used a pickle fork to separate them, that may have damaged the uppers, but, I don't think that would account for your noise. Humming is usually a bad bearing....
