Tranny wont catch gears
Old Apr 16, 2011 | 11:51 PM
Sparky360's Avatar
Sparky360
Default Tranny wont catch gears
Whenever I'm in park going to drive. My truck somtimes dosent catch gear and go into drive so I maximize the RPM (only a little bit) till she catches.
This hasn't been a problem until i changed my tranny fluid, filter, and gasket. I went to NAPA and they gave me the tanny filter but it didn't have the metal "shell" only the interior filter. They said it wouldn't be a problem besides it was either a $6 filter without the shell or $45 filter with the shell.
Or could it be the type of fluid I used or that I might be runin low?
Always Appreciate it guys
~Sparky
Old Apr 16, 2011 | 11:57 PM
97Rampowerhouse's Avatar
97Rampowerhouse
what type of fluid did you use? ATF +4? did you do a complete transflush or just drain the pan also did you put the truck in neutral and check the fluid while it was running?
Old Apr 17, 2011 | 11:38 AM
Sparky360's Avatar
Sparky360
It was ATF +4 and we just drained the pan. and ill also check it in neutral see if its low.
