track bar..
Old Apr 18, 2011 | 01:51 AM
TryMeImHard's Avatar
TryMeImHard
Default track bar..
well i finally got the track bar and was going to swap it out.. pretty simple right??
Nope.. i was able to get the frame end off but the axle end was another story i soaked it all day with PB and still no turn(with impact) so i'm guessing to keep soaking it??
no way to grind it off is there??
Old Apr 18, 2011 | 02:04 AM
Mad_Scientist's Avatar
Mad_Scientist
Must be the salt up there in MI. Mine came off without much trouble.
2 things I always try when I cant get a bolt to turn: mechanical shock (which you already tried with the impact) and heat... or a combination thereof.
Get yourself one of those propane torches (the big one that uses a bottle) and heat the area around it up. Then hit it with the impact, then torch, then impact, etc. Eventually (usually after many beers and swear words) it will come loose.
Just dont get too trigger happy with the impact, or you'll break the head off of the bolt.... and that's a whole 'nother problem.
Also, note that the rubber bushing in the track bar will probably catch fire when you hit it with the torch, so be prepared for that.
Old Apr 18, 2011 | 02:22 AM
TryMeImHard
yeah man you drive 2 years here and you got rust i'll try the heat... i was thinking the PB would catch fire but thanks for the heads up on the bushing
Old Apr 18, 2011 | 02:34 AM
Mad_Scientist
Id wait a good while to let the PB evaporate before you do this, just to be on the safe side.
Old Apr 18, 2011 | 07:20 AM
dhvaughan's Avatar
dhvaughan
+1 on using a plumbers torch to heat the head of the bolt. it takes it awhile to get the bolt hot enough to make it stretch. i don't think the PB will catch fire. it'll just evaporate off.
heat, impact, heat, impact = it will eventually come out. just don't round off the head..
Old Apr 18, 2011 | 11:46 AM
ryan0714's Avatar
ryan0714
+2 on the heat, dont do it with it soaked in pb, but yes heat it up and get on it with ur wrench as fast as u can.
Old Apr 19, 2011 | 05:47 AM
TryMeImHard
well tried everything on it today had it spinning but wasnt backing out??? broke loose in back i'm guessing.. and i rounded the head...
looks like i got some drilling and cutting to.. and alot of swearing because it is not going to be fun..
Old Apr 19, 2011 | 07:48 AM
Got an oxy-acetylene torch? Blow the nut off the back, and the head off the end you can actually see. Try not to damage the bracket. Then pull that feller out.
Old Apr 19, 2011 | 09:37 AM
Mad_Scientist
Wedge a wrench on the nut in back, and get a slightly smaller socket for the front. Beat said socket on to the rounded off head (and I mean beat). Try again.
