my 25% pulley needed a new belt. I had to go with i wanna say 95 3/4 inch belt. u can try it but like i said mine didnt work i could slip the belt on and off without touching the tensioner...good luck
I also only run the u/d crank pulley
Reason: forgot to state i only run crank pulley
seems like a good item. 12 rwhp is typical? Im wondering if a local auto parts store would have a 95 inch belt. This seems like an easy DIY. Can someone posts a link to the underdrive pully. Im guessing just the crank is all youd need right? I love learning about another mod to add. I swear its addicting lol
If you do only the crank pulley you'll find that your alternator puts out almost nothing at idle speed. It's better for battery life to get the smaller alternator pulley along with the crank pulley to bring it back up to operating speed at idle.
Very true!
I wouldn't do the water pump pulley, the last thing you want to slow down is your cooling system.
