tires leaning in at the top - questions?
Old Apr 19, 2011 | 04:15 PM
catalyst's Avatar
catalyst
Default What do I need to adjust camber on 98 ram 1500?
my tires are leaning quite a bit.
4 new ball joints
new tie rods / stabilizer bar links / stabilizer.
In the process of changing all this out, I was told that I'm missing the Cam / cam bolt on my lower control arms. It looks like the factory bolt was removed, and there is now a grade 8 bolt / washer put in place.
There is a 4" lift on the truck, and I still need an alignment. Will I be ok with just the grade 8 bolts in there, or will I need the CAM's? and if so... does anyone by chance have a part number so I can buy the cams / bolts? and do those cams / bolts adjust the camber?
Old Apr 19, 2011 | 04:50 PM
Skab's Avatar
Skab
http://www.rockauto.com/catalog/rafr...1314583k945406
Not to bad on price either. You should get these before you do alignment since it's one of the things they adjust.
Old Apr 19, 2011 | 07:27 PM
catalyst's Avatar
catalyst
that link didnt work correctly. it shows me a camshaft position sensor. what was is supposed to link to?
is this the item?
1998 DODGE RAM 1500 PICKUP 5.9L 360cid V8 MFI (Z) OHV : Steering : Pinion Angle Adjusting Bolt?
or:
1998 DODGE RAM 1500 PICKUP 5.9L 360cid V8 MFI (Z) OHV : Suspension : Caster / Camber Cam Bolt Kit??
