Gears
Old Apr 20, 2011 | 10:32 PM
gipperkid's Avatar
gipperkid
I'm not trying to hijack this thread, but I've got a factory 4.09 ratio front diff to swap with my 3.55 diff. But I was just going to have the gears swapped in the rear. On Randy's site, the Yukon gear only comes in 4.11, why not 4.10?
Old Apr 21, 2011 | 09:59 AM
I would pull the cover on that 4.09, and count the teeth, and do the math...... probably gear ratio is also etched into the ring gear somewhere. Clean it off and have a look. Rather an odd ratio for a dodge, wasn't available from the factory that way, and all I have seen for 'em is 4.10's. (maybe someone is doing some different rounding?)
Old Apr 21, 2011 | 11:44 AM
rl99dram's Avatar
rl99dram
4.88s, my dodge runs like a champ.
Old Apr 23, 2011 | 11:23 AM
gipperkid's Avatar
gipperkid
RING GEAR: 45 PINION: 11 (45/11=4.0909090909 and so on)
Old Apr 23, 2011 | 12:04 PM
Dycrow27's Avatar
Dycrow27
now with 35's changing my gears to 4.1 or 4.56 wont change the mpg will it?
Old Apr 23, 2011 | 12:15 PM
With 35's, going from 4.10s, to 4.56 will probably get you BETTER mileage.
