yay codes
Old Apr 23, 2011 | 04:38 PM
dipsherry's Avatar
dipsherry
Default yay codes
31 32 27 well i assume the one is due to my egr being disconnedted but what would cause my other 2 one is a evap and the other is the injector control circut???
Old Apr 23, 2011 | 04:39 PM
dipsherry's Avatar
dipsherry
could i of maybe hooked up a vaccume line wrong but to b honest what is the evap??? i just got done switching my intake...so i am sure thats the problem
Old Apr 23, 2011 | 05:21 PM
31 is purge solenoid circuit, make sure the solenoid is indeed plugged in, and the wires didn't get pinched somewhere.
32 is EGR, fault in diagnostics, since you don't have an egr valve anymore, that one is completely understandable.
27 is Fault in injector driver interface circuit. About all I can find for this one is:
1. The injector resistance should be in the range of 10-20 ohms. Check at the clip.
2. At the PCM check for resistance to ground on each driver circuit. This is the PCM driver to ground and it should be greater than 5 ohms.
3. At the PCM check the resistance of the circuit to the clip, it should be is less than 5 ohms, that indicates a good circuit. This is done with the injector clip removed from the injector.
Beyond that, it is an internal PCM issue...... supposedly.
Old Apr 24, 2011 | 09:31 AM
dipsherry's Avatar
dipsherry
Could it be due to me changing my injectors...this code didnt arise till after my second intake swap but I changed injectors with the first intake swap....
Old Apr 24, 2011 | 10:22 AM
Did you have to change the connectors for the new injectors? If you did, I would take a close look at your splices.
If not, check and be sure all of them are plugged in good, and the connections are clean.
Old Apr 24, 2011 | 01:13 PM
dipsherry's Avatar
dipsherry
no the connectors were the same just had one not snapped all the way down and there was a plug wire not connected to distributor...but didnt get a missfire code lol...now she runs like a top again and all is good thanks heyyou ur the man...also i just got the little egr sensor pluged it in and zipped tied it then i fixed the vaccum leak on the purge. So no light YAY :-)
Old Apr 24, 2011 | 03:17 PM
Cool, Glad ya got it fixed.
