Tool needed to lower the spare tire
Old Apr 23, 2011 | 08:29 PM
Seth_787446's Avatar
Seth_787446
Default Tool needed to lower the spare tire
When I bought the truck it came with no spare jack or the extension. So now I can't get the spare tire down. Any ideas on how to raise and lower it?
Old Apr 23, 2011 | 08:35 PM
jasonw's Avatar
jasonw
Site Moderator
Buy the jack/kit on eBay. Mine came with the wrong jack, assuming previous owner just threw one in at some point and forgot about it when he sold the truck. I got mine off of eBay from a wrecked Ram, works great.
ryan0714's Avatar
ryan0714
u just wanting it off? or you still wanna use it? you can just cut the cable... or you can get the actual tool from the dealership. but im not sure if you could get anything else to work... its about the size of a regular 3/8s extension, dunno if it would turn it though.
Old Apr 24, 2011 | 12:16 AM
redheadhunter21's Avatar
redheadhunter21
Find the right size hex for it, I cant remember what size it is but thats what I use when Im at the house, and just use my regular ratchet
Old Apr 24, 2011 | 12:25 AM
Seth_787446
That's exactly what I was thinking but Sears only has a 10mm for the biggest size, I would know I just drained the transfer case.
Old Apr 24, 2011 | 12:28 AM
redheadhunter21
Damn that sucks, im not even sure what brand mine is might want to check local auto stores and see if they have them big enough
Old Apr 24, 2011 | 12:36 AM
Seth_787446
I'll check tomorrow but if you find out what size your hex bit is could you please let me know?
Old Apr 24, 2011 | 03:44 AM
99dodge318's Avatar
99dodge318
i had the same problem plus i cant fit a 35'' tire in the spare location, so i just removed my whole tire and which combo,
theres a cotter pin under the tire that connects the lowering rod to the winch.
pull the pin,
remove the rod though the hole above the bumper,
reconnect the rod with the pin so you can crank it down by hand.
after that theres only four bolt attaching the winch to the rear cross member, a ratcheting wrench made short work of that.
Old Apr 24, 2011 | 08:13 AM
dhvaughan's Avatar
dhvaughan
i think i used a 1/2 inch drive extension stuck into the spare's hex socket, and it worked.
Old Apr 24, 2011 | 06:34 PM
redheadhunter21
5/8th's hex head from Snap-On is what I use, add an extension to a ratchet and its up and down in no time
