rebuilt trans
Old Apr 24, 2011 | 05:39 PM
dvowicker's Avatar
dvowicker
Default rebuilt trans
so i was having trouble with my tranny with it shifting out of o/d well i got it rebuilt and put in. i am now having the same problems with my tranny as i did before but this time i got a code p0734 which is a 4th gear ratio code. it also says transmission speed sensor so i went out and swapped it but it still is doing it any suggestions guys?
Old Apr 24, 2011 | 05:46 PM
Mad_Scientist's Avatar
Mad_Scientist
Hmmm... Could be a internal PCM issue or a wiring fault somewhere which would feed the comp bad info
Old Apr 24, 2011 | 05:56 PM
dvowicker's Avatar
dvowicker
it never ends lol but hey it shifts better than before until o/d any way of checking the things u said
Old Apr 24, 2011 | 07:40 PM
P0734 Gear 4 Incorrect Ratio
Wonder if that implies the PCM is commanding 4th gear, but, not seeing the RPM drop it thinks it should?
Does your truck actually shift into fourth? TCC engage?
Old Apr 24, 2011 | 07:49 PM
dvowicker's Avatar
dvowicker
Well it does shift into overdrive sometimes not always o btw I just went for a drive and I was shifting manually with od off when I get up to the rpms for od to engage and push the button so overdrive is back on it doesn't shift but does make the rpms climb 500
