crazy oil pressure gauge????
Old Apr 24, 2011 | 08:15 PM
dipsherry's Avatar
dipsherry
Default crazy oil pressure gauge????
ok so finished truck....Well so i thought driving back home i notice oil pressure went from great 40psi to noting like truck was off nothing... so i pulled over and shut er down right away....checked everything she was full of oil all was great...started up and oil pressure was back...but as soon as you hit the gas and it gets over 1500 rpms it go dead again. but if driving and u turn off turn back on it has shows oil pressure and its great...so after about a mile of me shutting truck on and off 50 times to check oil pressure i just drove the 40 miles home no problems got home shut off turned on and pressure was great. what could cause this
Old Apr 24, 2011 | 08:18 PM
dodgeram07's Avatar
dodgeram07
try to put a Mechanical Oil Pressure Gauge on it
Old Apr 24, 2011 | 08:24 PM
matty675's Avatar
matty675
sounds like a clogged pick-up
Old Apr 24, 2011 | 08:28 PM
dipsherry's Avatar
dipsherry
i just sent the g/f up to the parts store to get a sending unit but they are closed...where is the sending unit located at
Old Apr 24, 2011 | 08:31 PM
dipsherry's Avatar
dipsherry
if i turn truck off and start it up rev s can be at 2500 and it shows oil pressure...if the pickup was clogged would how can i have 40 psi at idle then as soon as i hit gas the gauge goes to nothing not slightly goes down just a immidate drop like you turn the truck off
Old Apr 24, 2011 | 08:47 PM
ryan0714's Avatar
ryan0714
sending unit is on the passenger side of the distibutor. u can use a cresent wrench but they do make a socket just for the oil sending unit, and its wayyyyyy easier.
if the sending unit dont fix it, i would just throw a mechanical guage on and ground the original sending unit connection to itself, and call it a day.
Old Apr 24, 2011 | 08:56 PM
dipsherry's Avatar
dipsherry
yeah just found it u unhooked it and it doesnt have the light...which will work for now just gonna throw the mech gauge on it and call it good....i might do the sending unit tomorrow after work if i feel like it
Old Apr 24, 2011 | 09:15 PM
Mad_Scientist's Avatar
Mad_Scientist
I used to have a 92 chevy that would do the exact same thing... replaced sensor after sensor with no luck. No valve rattle, no ticks, the gauge just wouldn't read correctly.
I finally found the problem when tearing into the engine to replace a head gasket: there was a wire rubbed bare which would ground out on the body upon acceleration due to wind/g-forces. Covered it with e-tape and it solved that particular problem (and as was that chevy's trick, birthed another, more serious problem).
Old Apr 24, 2011 | 09:36 PM
dipsherry's Avatar
dipsherry
Well I just fixed the intake and I never had a problem before....so I could of pinched a wire hell thousands of possibilities lol
Old Apr 24, 2011 | 10:06 PM
dhvaughan's Avatar
dhvaughan
did you change the oil after the intake fix? sludge, gasket pieces, etc can fall down into the pan and might be sucking up on the oil pump intake.
