What is this valve on top of the valve cover, it's NOT the PCV
Well I guess the only good thing about that is to replace the valve covers haha but thanks for the advice, I will continue to pull on it and hopefully I can't get the sucker to come out, you say it's hard to get back in?
Putting it mildly. Coming out took about 15 minutes. Going back in took me over an hour....... And I don't even remember why I pulled the damn thing. Or even if I did it on purpose........
I think the easiest way to install/remove that thing, is to pull the damn valve cover....
The easiest way is to run the engine up to normal operating temperature for around five minutes, then squirt a little penetrating oil around the base of the elbow. Grab hold of the elbow with a rag, and pull. Putting it back while the grommet's still nice and warm is cake, piece of, one each.
BTW, for those who aren't aware of it: 05h17 = "oh <poop>".
Well that does sound like a PITA haha I need to pull mine though because of the oil coming out of it (going against the air flow though is strange....)
I know it doesn't pertain to ur problem, as ur having an issue with the elbow but just to clarify: The smaller filter I was talking about works the same as the tube going to the air filter does, minus the tube. It sucks clean air into the crankcase. And looks cooler.
why not, truck is only 26 years old...
no one seemed to clarify it much but when i brought the part to oreilly I thought it may be useful to others
Not relevant. If he didn't have enough of an answer, he would have said so, YEARS ago. It is against forum etiquette to resurrect long dead threads. Please don't do that.
Just curious, what is the valve that sits on top of the valve cover on the drivers side called? I know it's not the PCV but it has a hose running from it to the air hat assembly. It is starting to leak/seap oil out of the top of it and into the hose.
are you referring to the crankcase breather? They'll plug up too and cause blow-by issues
