fuel pump problem?
Old Apr 25, 2011 | 06:22 PM
sweetshredder's Avatar
sweetshredder
Default fuel pump problem?
Last week my 2001 ram 1500 5.9 began buckin from a stop to start. The engine light will come on briefly and the fuel gage will drop to show emty. then pause and it begins to run decently again. its seams to be intermitent as it doesnt always happen. I ran the codes and no hard or soft codes are present. any ideas? i was thinking fuel pump assembly. but dropping the tank on a chance is alot of gamble. thanx
Old Apr 25, 2011 | 08:08 PM
jasonw's Avatar
jasonw
Site Moderator
Check the fuel pressure at the rails, see if you get inconsistent readings. A Haynes manual has the procedure.
I'll move this to the 2nd gen section, get you additional help.
Old Apr 25, 2011 | 09:01 PM
sweetshredder
Thanx jason, I actually have the manual open and am reading thru the fuel section and ckp section as well,
