beef up Handling
Old Apr 28, 2011 | 12:22 AM
whatman27's Avatar
whatman27
Default beef up Handling
hey everyone i have 94 dodge ram1500 an im looking to make it handle like a indy car lol. i figure changing all bushings would be a good place to start but then in go blank.
Any suggestion or ideas would be appreciated.
Old Apr 28, 2011 | 12:35 AM
dodgeman2289's Avatar
dodgeman2289
new or better sway bar will help u take corners better truck wont shift. making handleing better
Old Apr 28, 2011 | 12:40 AM
redheadhunter21's Avatar
redheadhunter21
change bushings to energy suspension bushings, upgrade sway bar, rear sway bar, stiffer tire with shorter sidewall, check all joints for play and replace as necessary
Old Apr 28, 2011 | 12:45 AM
whatman27's Avatar
whatman27
any ideas how much a performance sway bar would cost ? or a specific brand ? and rear sway bar lol i did not think of that, they those for are trucks ? or would i have to custom fab one ?
Old Apr 28, 2011 | 01:00 AM
whatman27's Avatar
whatman27
Another Question for everyone.. is there such thing as a performance drop for our trucks ?
Old Apr 28, 2011 | 01:15 AM
dodgeman2289
Prob 200-400 for a sway bar start looking them up all i can say
Old Apr 28, 2011 | 01:38 AM
redheadhunter21
Look for drops with springs in the front and the drop springs will give a stiffer ride and the lower center of gravity will help a bit too. Another thing drop shocks have a stiffer valving to them and will make a lot of difference when going over bumps and through corners
generaljr's Avatar
generaljr
2wd or 4wd, if it is 2wd I have a good one. my truck was lowered 2 front & 4 in the rear with a belltech kit that uses lowered coils in front, shackles & hangers in the rear. handling was excellent at high speed but needs a good set of shocks.
Old Apr 28, 2011 | 02:05 AM
thetypezero's Avatar
thetypezero
Id say a 4 front 6 rear lowering kit would be a great improvement. You could get a bigger wheel with a lower profile tire that should help also.
Old Apr 28, 2011 | 02:21 AM
redheadhunter21
Dont think I would go that low for drivability, would stay around 2/4 or 3/4
