4x4 Clunking/Clicking noise???????HELP!
Old Aug 3, 2011 | 01:27 PM
Kierbo77's Avatar
Kierbo77
Could it be that simple
Old Aug 3, 2011 | 01:30 PM
Its possible..... something to look at anyway, it is a common point of failure.
Old Aug 3, 2011 | 01:37 PM
Kierbo77's Avatar
Kierbo77
Could it be that Simple? Are you sure?
Old Aug 3, 2011 | 01:41 PM
Sure? No. But, it IS a known failure point, and it can give the same symptoms you are talking about. It doesn't hurt to check, just to BE sure that is NOT it.
Do a google search on transfer case saver. You will find that this is such a common failure, the aftermarket came out with a Fix for it.
Old Aug 4, 2011 | 08:25 PM
Kierbo77's Avatar
Kierbo77
The transfer case on my truck has never been touched since the truck was brand new. and Could there be cogs/gears missing the teeth from chipping that could be the chain slipping to
