Drink holder guts
Old Jul 4, 2005 | 05:07 AM
3500reddragon's Avatar
3500reddragon
Default Drink holder guts
Is there any place to get the guts to the large drink holder located in the low center of the dashboard assembly of a 1998 Dodge Ram? Mine is broken & after investigating the construction, it appears that the guts could be swapped out or replaced very easily.
Old Jul 5, 2005 | 02:09 PM
Two60s98's Avatar
Two60s98
Default RE: Drink holder guts
Junk yard is your only chance at getting a specific piece... just spent $78 bucks on a cupholder assembly at the stealership. Only comes as an assembly new. Can't purchase parts seperate. (Grrr)
Old Jul 6, 2005 | 11:12 AM
Ivan928's Avatar
Ivan928
Mine was broken around one of the pivot points, I repaired it (See pic) by cutting/shaping and then glueing (Epoxy type) some thin Aluminium round the broken part, leaving for 24hrs to harden and then snapped it back into position, been fine since then.
I always need to know what broke and why!!!! If its cost effective/fixable and will last I try and fix it, otherwise I take a hit in the pocket.
[IMG]local://upfiles/9685/47EFB428B98F49D7A082E476545980A7.jpg[/IMG]
Old Jul 6, 2005 | 10:16 PM
3500reddragon
Yeah, I figured the junk yard was good for this kind of stuff, but I can't find it locally. Will have to search on line at linked junkyards and probably pay premium. Unfortunately, it's not fixable as the lower half of the mechanism is missing. I am also one to repair things. Just fixed the ashtray which wouldn't stay closed because the leaf spring was loose due to the plastic housing being broken. A bit of epoxy in the right spot & position fixed it just fine!
