wont start after up to temp ?
Old Apr 29, 2011 | 07:11 PM
countryboy94's Avatar
countryboy94
Default wont start after up to temp ?
I have a 94 dodge ram 1500 2wd with the 318 its nt getting a spark ounce the motor is up to temp and I turn it off go to start it again and it won't mak a spark but when its cold it fires right up with kno problems I need help evryone I no dosent kno either so I can help me give. Me some ideas of what it could be thanks scott
Old Apr 29, 2011 | 07:52 PM
madore33's Avatar
madore33
you could start by checking your coil and or coil wire..check the connection at the coil...
Old Apr 29, 2011 | 09:30 PM
countryboy94
I jujst put a new ingnition coil on it yesterday
Old Apr 29, 2011 | 09:41 PM
Magnum4406's Avatar
Magnum4406
Sounds like a bad crank sensor.
Old Apr 29, 2011 | 09:49 PM
countryboy94
But how why would it do it only wen its up to temp?
Old Apr 29, 2011 | 10:43 PM
Magnum4406's Avatar
Magnum4406
There is a coil winding inside the sensor that generates a signal to the computer. I work at an auto repair shop and have seen a bunch that run cold but once they get hot......nothing. Unfortunately it is a bit hard to get to on Rams. it is mounted on the upper passenger side of the trans bell housing. I have seen the same on G.M.'s also, they get warm/ hot and quit until it cools off.
Old Apr 29, 2011 | 11:13 PM
countryboy94
Ok I odered one from auto zone bout how long does it take too do one
Old Apr 29, 2011 | 11:31 PM
Magnum4406's Avatar
Magnum4406
Getting at the 2 attaching bolts is the tricky part. You just need to remove the 2 bolts, I usually get them from underneath. but I have it on a hoist and it is still a pia. Unbolt, unplug it and put the new one in. Super easy in a van with the dog house off... I hope this fixes your truck, It seems to me that you have eliminated all the other ignition problem areas. The Distributor only controls the injector timing (cam sensor is inside).
Old Apr 29, 2011 | 11:42 PM
countryboy94
Old Apr 29, 2011 | 11:49 PM
countryboy94
I have a car lift so it should be a lil hard then
