wont idle
Old May 1, 2011 | 11:06 AM
byronpen's Avatar
byronpen
Default wont idle
My 1999 1500 5.9l will not idle, when i start the truck, its fine after i get going, any ideas.
Old May 1, 2011 | 01:56 PM
generaljr's Avatar
generaljr
the most probable, is the idle air control valve, its located in the back side of the trottle body
Old May 1, 2011 | 02:12 PM
byronpen's Avatar
byronpen
Ive replaced that about a month back. Any other ideas
Old May 1, 2011 | 02:42 PM
botta's Avatar
botta
try the EGR valve, located by the oil pressure sensor on the back of the motor.
Old May 1, 2011 | 02:59 PM
drewactual's Avatar
drewactual
I don't think he has one of those.. I'd at least give the IAC a look see... it can't hurt, especially if it is an aftermarket one..
Old May 1, 2011 | 03:04 PM
generaljr's Avatar
generaljr
did you have rusted battery wires? if yes check for loose connections. my faulty idle was caused for a starter wire making contact with the engine
Old May 1, 2011 | 04:04 PM
byronpen's Avatar
byronpen
no my truck is in good condition, well keep
